Trevrev
- Southampton
After just over a year of having my bike i changed the disc brake pads (Hydraulic). Out came the old, and i replaced like for like ( Resin ). I'd never had an issue until i changed the pads. After about a month, they started squealing like a monkey in pain, and not really working very well. Took them out assuming contamination, cleaned all through with IPA alcohol, roughed up discs and put another new set of pads in. After a few weeks of perfect brakes, the same thing happened. As before, cleaned all through, and another more expensive set of pads. You guessed it, same thing happened. All noise and no brakes! A guy near me works in a bike shop, so i approached him and he took my bike away to have a look.
He cleaned the whole system through, did a re-bleed, and put sintered pads in this time. Roughed up the discs and all was great. Now it's happened again.......All noise and no brakes! Matey is on holiday, so i'd thought i'd pick the brains of my fellow cyclists.
What is happening, and what can i do.
Everything was fine with the original Pads that came with the bike.
There are no leaks on the hydraulics either.
Any help would be very grateful.
Also used, muc off, brake and clutch cleaner. I even boiled one of the sets of pads.
Could the discs be the cause of my problems? They look fine!
Cheers.............Trev.
