Disc Brake pads
ScotiaLass
Middle Earth
I think I need new front pads for my brakes.
This is the spec:
Front Brake:
Tektro HDC-330, hydraulic disc, dual piston, tooled reach adj., Light Wave style rotor, 160mm rotor
Can someone tell me what I need to buy to replace the pads?
ianrauk
Tattooed Beat Messiah
Rides Ti2
HERE you go, I think these are the ones
Falco Frank
Oup Norf'
I found some pads on Ebay from a manufacturer called EBC that I've known and used before in the motorcycle world, so I trust them as decent quality.
Not sure about your Tektro brakes but I found it easier to leave the wheels in and remove the calipers to examine and replace the existing pads on my Magura's.
Good luck.
ScotiaLass
ScotiaLass
Middle Earth
Good luck.
I looked at some from EBC but didn't know the make or what the heck I was looking for!
I have a work stand so plan to watch some You Tube vids and go from there!
Cubist
Still wavin'
Ovver 'thill
Thanks @ianrauk
Any particular ones or would all of these fit?
Sorry, I know nothing about this!
No, just the top selection, the Auriga type with the return springs.
Other links so you can choose your compound ( I'd suggest organic for cheapness, Kevlar (or Uberbike matrix) for performance) would be Superstarcomponents ..Pad S2 on their identifier. :
http://www.superstarcomponents.com/library/pdf/BrakePadIdentifiier.pdf
http://www.superstarcomponents.com/library/pdf/PadChart.pdf
order here: http://www.superstarcomponents.com/en/shop/mountain/mountain-braking/mountain-disc-brake-pads/
or Uberbike on ebay.... use Tektro HDC 300 as your search terms:
http://www.ebay.co.uk/sch/i.html?_f...e+HDC+300.TRS0&_nkw=uberbike+HDC+300&_sacat=0
Nothing to choose between them, they probably come out of the same factory, but Superstar will send you some free Haribo or stickers.....
Falco Frank
Oup Norf'
The EBC website took a bit of digging through to find a fitment guide:
http://ebcbrakes.com/Assets/MTBfitments.pdf
A 330 is listed but Tektro are mentioned three times, drawings of the pads themselves at least are shown.
Here are some on Ebay but not sure if these are yours - seller is good, Ive used them myself:
http://www.ebay.co.uk/itm/Ebc-Tektro-Novela-Gemini-Disc-Brake-Pad-CFA-330-Green-/181754518243
Cubist
Still wavin'
Ovver 'thill
Those are the Gemini..... not the right fitting as you suspected. EBC sell them, but only via German sellers on eBay... at over a tenner a pair unfortunately.
