slowmotion
Quite dreadful
- lost somewhere
I have used a gel silicone remover like this a few times...
http://www.geocel.co.uk/product.aspx?id=66&pt=diy
Carefully cut off as much excess silicone as you can using a really sharp Stanley knife of scalpel. Don't be tempted to cut too close to the bath surface though, or you may scratch it. Then paint on a generous coating of the gel and leave it for a while. Scrape off the softened silicone with a a non-metallic scraper, and repeat as necessary. Clean the surface of the bath scrupulously, as per instructions by the gel manufacturer. When you re-apply the silicone, use a low modulus sanitary silicone that resists mould growth. After applying, remember that you only have a couple of minutes to smooth it. ( Using masking tape helps to make a neat job) If you tool it after that, you will drag the surface skin and it will look like Hell. Good luck.
