Genuine question: why would you ever need to re-use a quick link? To swap a chain, use the new quick link with the new chain.
But - some brands of chain don't come with a quicklink. I always buy KMC chains because they always provide a quicklink.
Carry it! Stuff happens and it is one of the few tools that you will not be able to borrow from a non-cyclist if the worst should happen.
I have used mine 'in the field' a number of times, although rarely for my own bike, but it can/does happen and the repair is preferable to the alternative.
I think the point of a quick link is just to install the chain. Chains come with one (except for shimano IIRC who have some fancy once use rivet)
But every new chain I've ever had has needed shortening first, and that's required a chain tool anyway, so it doesn't save a lot just on initial fitting.
I use quick links to take chains off for a thorough clean every now and then - probably only 2 or 3 times during the life of a chain, but everything that makes that easier helps. I also recently used a quick link to remove a chain so I could replace a derailleur (having found a better vintage model).
But at least 10s and 11s chains can't be rejoined with a chain tool AFAIK, so you need the quick link just to fit the chain.
...Genuine question: why would you ever need to re-use a quick link? To swap a chain, use the new quick link with the new chain.
Of course they can, rejoined a 10 speed many a time.
Ah, I see - but not a problem for me as all my chains are 9-speed or less.But at least 10s and 11s chains can't be rejoined with a chain tool AFAIK, so you need the quick link just to fit the chain.
Me too. Another good reason, unless some overbearing need, to not go higher than 9. Keeps things simple.Ah, I see - but not a problem for me as all my chains are 9-speed or less.
For the once every 3 monthsGenuine question: why would you ever need to re-use a quick link?
