Fifelad
- Carnock,Fife
Just fitted new rear derailleur cables inner and outers, jockey wheels still in good conditon and the gears are indexing perfectly, it’s just when in the lowest gear there is excessive noise like the chain is not sitting exactly right on the jockey wheels. I’ve adjusted the B screw to the limit in both directions and the jockey wheels are in the correct way around and guide in the correct position ie tension and guide wheels. The only thing I can think of is the hangar could be a minuscule bit out of line ?
