emulsifier12
- Nuneaton
Here is some software called OsmAnd, for your Android phone that uses turn by turn navigation from GPX files. You create a GPX file (custom cycle route) and then it uses your GPS to follow that route with turn by turn navigation by voice and on screen display.
I struggled to find a free program that does voice navigation of GPX files. There are many programs that can record and track your ride and create GPX files from your rides, but none that can use the GPX file to give you turn by turn navigation by voice. It allows you to download the maps and gpx files and use them 'offline'. No need for expensive data costs. Below are some instructions on how to install and configure it. I hope that my instructions below are accurate and will help you. Let me know if I need to add or change anything. I thought I would post this in know how section as it explains how to install and setup the software.
OsmAnd (Open Source Maps for Android) version 0.7.1
https://play.google.com/store/apps/details?id=net.osmand&feature=nav_result#?t=W251bGwsMSwyLDNd
or
http://www.appbrain.com/app/osmand/net.osmand
1. Install OsmAnd via Android's Play Store. I also installed 'OsmAnd Voice Import' and 'OsmGpxUploader'
2. Download offline maps. Click on settings, offline data, download and click on europe to expand and then on the UK map, GB england europe (zip) Map 290mb. Set the software to use offline vector maps under settings, map configuration and tick offline vector maps.
3. Download a voice, use the same menu from settings, offline data and click on download and browse the voices. I have used a TomTom voice called 'tim loud' that I downloaded from a 3rd party website. Change the voices under settings, navigation and voice guidance. You can test the voice under settings, general settings and test voice prompts.
4. Register on http://ridewithgps.com/, create a route, make sure that the start and end are near to each other but not the same spot (do not overlap) as the software (OsmAnd) gets confused with looped routes.Save the route and then download the GPS file to your phone.
5. Create a folder in the OsmAnd folder on your SD card under OsmAnd called tracks (sdcard/osmand/tracks.
Copy your 3rd party downloaded voices into the voices folder.
Copy your .GPX file you exported from RidewithGPS into the tracks folder.
Activate / Turn on your phones GPS.
Open OSMAND.
Click on your menu button on the black part of screen, (mine is the one with 4 lines, between home and the back button), this brings up a load of options,
1. click on define view, tick the boxes you want, for me it was GPX track, overlay and underlay map. then back to the top of the screen, click on Map Source... choose offline vector maps. (the ones you downloaded earlier will be used).
Now to navigate.
2.click on menu button again and click on directions, gpx route and choose your gpx file. Click on tick boxes, I chose use current destination and pass along entire track.
Then let it navigate for you.
or
Open OSMAND.
Now to navigate.
