As I mentioned in a post elsewhere about running out of mounting space on my handlebars, I'm curious as to whether anyone has used one of these:
http://www.wiggle.co.uk/topeak-fixer-66-bracket-for-phone-bags-etc/
From what I can gather, it replaces the stem cap and allows for the mounting of "bits and bobs". I'm thinking it could be a handy place to relocate my computer to.
Thoughts?
I saw something similar the other day which had a small extension bar on and thought it was a good idea, till I realised their was no advantage in having one, all it does is stops me mounting my Garmin Edge on the stem, so in effect its replacing one mounting space with another mounting space with no gain and makes life even more complicated, unless your happy riding with it all the time, it means having to mess about with your steering everytime you fit it and remove it and also the additional problem of aligning it to your steering as well as your front wheel and bars.
What I use is a Minoura Space Mount SG400-Short:-
http://www.sjscycles.co.uk/minoura-space-mount-sg-400-short-extension-prod32043/
So I have my Edge on the stem, Cycling computer on the RH side of the bars, Space mount on the LH side of the bars with the map board and front light mounted on it, and when it comes to removing it, I can do so in a minute of two or two with everything still attached.
But I have found that it needs fixing down tight as it has a habit of coming loose on the bars and even threadlock on a small screw that holds it together.
It does what I want, now that I know its faults, and their probably is better on the market similar.
If you look through the following, you may see something better or what may match what your looking for:-
http://www.sjscycles.co.uk/accessory-fitting-brackets-dept785/
