Trials & Tribulations:
So I stood in the garage last night, tea in hand, brooding over if I should just make a simple loose head bearing adjustment or 'delve a little deeper'.
Fatal for me really.
The overseat steering in my opinion, ever since I got the bike does not feel logical or as comfortable as it could be, so I've been keen to try the USS, asap!
I'd hoped to be able to install the USS bar while all the overbar kit was still installed but the steerer tube simply would not fit and I couldnt see inside the fork tube.
Within 5 minutes the front loading bar assembly was off, as was the very cleverly designed Terracycle 'tiller' for want of a better word.
Once I'd suspended the boom from the garage roof and gotten the forks out, I could see the reason why my puny plan had failed. A 'triangle' slider (for want of yet another word) had been left installed from the last time the USS had been used - this had solidly corroded itself in place and took some time to extract safely.
The head bearings were starting to run a little dry and were in need of some TLC. I was pleasantly pleased to see that needle roller bearings are fitted to the bottom assembly with good old balls in the top.
Why is that my bursts of progress always seem to get blighted by a problem?
While assessing if the friction due to the hub dynamo is really as much as an issue as I think it is (and it is!) I could not help but notice that the front disc is badly warped, not surprising for such a thin sliver of metal trying to slow down so much velocity, ha haa.
Are all 180mm discs capable of being interchanged dear readers or do I need to stick with an original, Magura, in this case?
A quick look at the very basic forks showed them in great condition, thanks to its black rubber slider booties, I imagine.
While a final try of the USS bar in position left me a little nervous, especially after some of the impressions I've read on the 'net, it wont stop me, as long as I can figure how on earth the controls are meant to mount, vertically!
Ciao - Frazzled Frank
