steve52
I'm back! Yippeee
- bottesford scunthorpe
please as a newbi,dont beat ya self up, the most important thing it to enjoy the rideing ,then you will still be rideing in ten years, you will get fit and faster, but let it come?
Hi Jeff, pretty new here myself....
Also gained a lot of valuable new information by reading through this thread. The cadence and not being afraid to use the granny gear, spinning like mad on inclines and feeling embarrassed to be hardly moving is me. I'll just go with it from now on. Thanks everyone and welcome aboard Jeff
Just a thought, I don't think anyone has mentioned saddle height yet. If it is too low (very common with newbies) it will make the legs ache quite badly, especially around the knees.
An easy way to get it about right is to set the height so that with the heel on the pedal your leg is straight at the bottom of the pedal stroke. The leg will then have roughly the right amount of bend when the ball of the foot is on the pedal and you can fine tune it from there.
I hope this is of use.
This sounds about right. I'm the same on my bike.This is most interesting. I have checked the pedal stroke you have mentioned and find my leg is bent and not straight, with my heel on the pedal. I have raised the seat this evening and will see tomorrow. I now have to stretch my leg on tip toes to reach the floor with the seat at this height. Before I could just reach the floor ok! Is the bike frame too high for me, won't be returning back to Halfords, will have to live with it!
If you have difficulty at all, the trick when coming to a halt is to transfer your weight on to the pedals and just step down as you stop. Dead easy, honest.
Pins & needles isn't something I've had a problem with so not sure there. Do you wear gloves at all? Some padded mitts may help.My seat was originally as low as it could be, but now looks similar to other hybrid cycles, looking on the web. I also get pins & needles in my hands, but this is probably my death like grip on the handle bars.
I'm glad it's helped.Tried lifting the seat last night and biked it into work today. All I can say is, what a difference! Immediately noticeable and my legs feel better tonight, in honesty the best they have ever been. Thanks for your advice.
Thanks for that. I've added a post to the "My advice to newbies" sticky in the beginners section.This seriously needs to be a sticky at the top of the beginners board.
I've been commuting for just under 2 years looked at my saddle height this afternoon after reading your post.
I raised mine by about 4-5cm and what a difference!
I found keeping my cadence was easier in harder gears which meant that I did my 10 mile route home (uphill) in just under 40minutes at an average speed of 15.2 mph. Beating my previous personal best by around 3 minutes !
Thank you
