zzpza
Previous projects:
Project Bike #3 - Paul Milnes
Project Bike #2 - Raleigh Sensor
Project Bike #1 - Apollo Equipe
Project Bike #0 - Peugeot
This was in a friends garage when he bought the house. Instead of throwing it away, I took it home.
After a good clean by zzpza, on Flickr
It's made from 531ST tubing, has a nice leather saddle and a Stronglight drillium crankset.
Stronglight Drillium Chainrings by zzpza, on Flickr
But, all the brightwork is heavily tarnished and the frame's rusting is several places. Thankfully it's all surface corrosion only.
More Rust by zzpza, on Flickr
So, I decided to give the frame a new coat of paint and rebuilt it.
Fist, I stripped the frame down.
Ready For Prep by zzpza, on Flickr
And took the crankset apart.
Need Cleaning by zzpza, on Flickr
The frame got a coat of Kurust and then acid etch primer.
Acid Etch Primer by zzpza, on Flickr
Before colour started to go back on.
1st Colour Coat by zzpza, on Flickr
I was going to go with flat bars and trigger shifters.
Reusable Parts + New Brakes and Headset by zzpza, on Flickr
Then I found an old set of Shimano 600 down tube shifters in the shed I had forgotten about. Shortly followed by a set of ally drop bars.
The saddle is a Wrights W3N. Any good? It seems pretty hard. I've never had a leather saddle before. I've since put some leather feed on it I use on the car seats.
Wrights W3N Saddle by zzpza, on Flickr
Fairly nice finish, I wanted to get the painting done as soon as possible as it was rapidly starting to get cold and wet - not good weather to be painting in.
2nd Coat by zzpza, on Flickr
I did a quick polish on the centre of the ally bars - just the bit that will show between the bar tape!
Polished Bars by zzpza, on Flickr
I did a bit of a 1200 grit 'polish' on the stem as it looked pretty bad. I'll do a proper polish at a later date.
Stem Cleaned by zzpza, on Flickr
This is after 2 coats of lacquer, a T-Cut and wax.
After Lacquer by zzpza, on Flickr
Fork and new headset fitted.
Fork Fitted by zzpza, on Flickr
Seat post, saddle, bottom bracket, shifters, bottle cage and stem fitted...
Saddle and Bottom Bracket by zzpza, on Flickr
Bars and levers (aero and cross top) fitted.
Progressing Nicely by zzpza, on Flickr
Getting ready to put the bar tape on.
Prep for Bar Tape by zzpza, on Flickr
Bar tape and brake cables fitted.
Bar Tape Done by zzpza, on Flickr
Just waiting for a rear mech, 8 speed cassette, chain and gear cables.
Any idea how old the bike is? It came with single pivot side pull brakes, 27" wheels, old style bottom bracket (i.e. not sealed), but no cotter pins. The head tube has "72" stamped in it, but it's too new to be 1972.
