1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Removing FSA Vero crank
Discussion in 'Bicycle Maintenance, Mechanics and Repairs' started by I am Spartacus, 23 Sep 2009.
  1. I am Spartacus
    I am Spartacus Senior Member
    N Staffs
    Can someone confirm that removing the drive side crank is done with an 8mm allen key? Undoing normally - anti clockwise? The crank then slides off and can be replaced?
    cheers all
  2. kyuss
    kyuss Senior Member
    Edinburgh
    Not quite. It's done with a crank puller. The bolt you see is just there to hold the crank on during use (and yes, it unscrews in the normal anti-clockwise direction) but the crank won't just slide off the BB once that bolt is undone. You'll still need a crank puller.
  3. I am Spartacus
    N Staffs
  4. kyuss
    kyuss Senior Member
    Edinburgh
    Yep, that'll do the job.
  5. I am Spartacus
    N Staffs
    Thanking ye... now awaiting a compact chainset and said puller...
