Suntour 2 Notched Cassette/Freewheel Removal Tool.
dan_bo
How much does it cost to Oldham?
Que?
smokeysmoo
smokeysmoo
If you mean those odd looking, bottle opener type gizmos... then no. Not in a long time. They usually always broke on use.
*Thread title now edited*
I was led to believe the rear hub of of my Record Sprint was a helicomatic one, but now I've actually had a look it is in fact a Suntour one, my bad D'oh! :blush:
So instead of one of THESE I'm actually after a Suntour 2 notched tool like THIS for this..................
Freewheel remover then... ah.
I don't think I have one. I have a Miche tool which fits most freewheels you get these days - i.e. splined.
PS Be prepared to use a big spanner and a long lever on it - like a garden hoe. Yup, I have my garden hoe set up to fit over a 12" adjustable spanner for the only reason of removing freewheels.
John the Canuck
..a long way from somewhere called Home..
it's a Suntour perfect freewheel..?
then ..hmmmmmmm
took mine apart
lockring first with a punch and big hammer - anticlockwise
remove cogs...76 small Balls will fall on the floor
place inner hub into a large vice - screw wheel off
BIN the Suntour and buy a new £10 freewheel
which uses a more readily available Shimano tool
John the Canuck
Hmmm indeed! I was only actualky going to remove it to clean it TBH...
:laugh::laugh:...i re-assembled mine [just for the hell of it.] using Rock n' Roll Web grease - runs well. Loathe to use again without a removal tool
My other freewheel [ I bought the Normandy 24 spline tool..£16..!] --- i immersed in 90wt gear oil overnight - in use, running well.
they both will prob still outlast the new Chinese made Shimano.!....^_^
