zimzum42 said:It's your fault for living somewhere wet and dirty
We're already off to a poor start with this one:I took your advice. Seeing as you're a serious cyclist.
My normal commuter is missing a wheel at the moment. So I used my road bike.
It has 700x23 tyres. Slick ones. And no mudguards. Which I didn't think would be a problem seeing as you, a serious cyclist after all, say that they're not needed.
I came out of work this afternoon to find the road wet. Not puddled, just wet. No rain though, quite bright actually.
So I thought I'd be ok seeing as you, a serious cyclist, don't think mudguards are useful.
I rode the 5 miles home along an A-road. The surface is ok. No puddles.
I topped 32mph, averaged about 18mph. I thought I'd be ok because of you.
I got home, disappointingly to find my shorts wet. My bike was also wet on the saddle, the saddle pack and down the seat tube. And my rucksack was dotted with drops of water from bottom to top.
Thanks Bonj. Thanks a lot.
it doesn't.a) regardless, you said it didn't matter.
again, it doesn't matter if your saddle gets slightly wet.There's a bit of exposed saddle between the top of the bag and my behind. Which you, a serious cyclist, would know. Unless you're so fat that your flab hangs over the back of your perch.
No it's not. it could have come from splash from other vehicles, mainly lorries and buses, or, the sky as rain.c) The only place the water could have come from was the back wheel throw. And if it wasn't a decent water-repelling cover there'd be more than drops on it.
I'm not complaining about getting wet. If I was at all bothered about that I'd have caught the train.
I'm just light-heartedly pointing out that bonj has been proved conclusively wrong about his mudguard position.
Which proves you wrong as well, young Joey.
And I go to bed smiling.
Goodnight!
Dave5N said:Birmingham water is different.
