Gixxerman
- Market Rasen
I have Halfords mini pump that can't get the pressures required for my Trek 7.3FX tyres.
Also as it attaches to the valve directly (no extension tube), it is very easy to damage the valve when pumping.
So, I bought a Topeak mini morph pump. However, I have having some issues with it.
1) No matter how many times I try to rearrange the bits in the head, I cannot find an arrangement that will sucessfully inflate a presta valve. One arrangement I found seems to the correct one, but even this will not work correctly. It takes a lot of force to get it on the valve, and even then it leaks unless you hold it onto the valve whilst pumping. My track pump works fine on the same valve so I know the valve is OK.
In the end, the bloody useless thing snapped off the top screw of the valve, thus knackering the tube.
I am not very happy about this, as I expected better fom Topeak.
Have I done something wrong or is the pump not working correctly?
I am thinking of just getting a presta to schreader convertor as this will protect the very delicate presta valve top screw.
2) My Trek 7.3FX only has only one mounting point on the seat tube (2 screws). This is already in use by my bottle cage.
The Halfords pump came with a mount that was a side mount and would fit beneath the bottle cage and still leave room for the pump. The mount that came with the Topeak pump does not.
So I am finding it very difficult to find a mounting point.
I have tried the top tube, but it fouls the rear shift cable.
Any ideas of how I can mount it?
Is there a similar side mount bracket for the Topeak?
I cannot use the Halfords pump mount as the clips are the wrong size.
