I have quite a big air compressor with a grit gun and even this isn't great for rust removal, so I can't see a power washer thingy being any good.
The best thing for rust removal is an angle grinder and cup brush with a small wire brush for intricate bits. Rust removal jelly works when used correctly, I get the worst off then use it in parts where pitting is still showing.
Good advice about the eye protection, but the more expensive cup brushes don't throw off wire like cheaper ones.Angle grinder and cup brush is indeed brilliant for removing rust from things like iron castings - let's say a fireplace or similar. I'd be dubious about trying to use it on something thin like a bicycle frame - but have never tried it to be fair. Word of warning - don't use a grinder - cup-brush or abrasive - anywhere near windows else you'll likely frost them. Also one snag with the cub brush things is having to pick out lots of pieces of steel wire from your legs afterwards, which is only a mild nuisance to be fair, but is certainly a reminder to wear goggles if one were needed
