Wheel Axles
Simon Head
Kidlington
Is it possible to put a rear quick release axle in a front wheel?
I want to do this so I have a longer Q/R axle that may be supported on one side.
Sharky
Kent
Dont know the answer, but do you mean the axle or the qr skewer?
Ajax Bay
East Devon
Have you got a front hub which is the same width (eg 130mm)? Have you got a fork with 130mm between the drop-outs?
I think you'll need to be clearer about your desired outcome to get a useful answer.
ETA (after @fossyant 's answer): The answer is YES. One could "put a rear QR axle [skewer] in[to] a front wheel [hub]". But having inserted the axle in the fork, one wouldn't be able to tighten it sufficiently to have any effect.
QR hollow axles are shorter than the distance between the frame dropouts. The QR lever squeezes the dropouts onto the axle cone locknuts. If the axle is longer is protrudes from the dropouts and you cannot compress them onto the locknut.
Ajax Bay
East Devon
QR hollow axles are shorter than the distance between the frame dropouts plus twice the thickness of the fork dropouts (2 x 6mm, say).
FTFY
Hope you don't mind this slightly pedantic correction (seeing we can get nowhere with the OP question being so opaque). Standard distance between fork dropouts is 100mm but the hollow (for QR skewer) axle is 108-110mm, typically.
https://www.evanscycles.com/weldtite-hollow-quick-release-axle-9x108mm-00101703
https://thecycleclinic.co.uk/produc...-front-rear-137-141-146-9mm-10mm-9-5x26-10x26
