Yup, no joyHave you tried just holding the cable under slight tension (not connected to the mech) and trying the shifter, it should obviously pull in / release as you operate it. If it doesn't, sounds like the shifter is U.S.
No worries, I couldn't find a groove anywaySorry just been to check. There is no groove on the 105 mech, it's straight from the adjuster to the clamp that holds the cable.
I've never had to change the 105 cable and I just remembered screwing up the SRAM on by missing the groove. Apologies.
I'll have a look what condition the lever is in. I know it's fully working but it may be scraped and scratched.
Lousy weather and been shopping tonight so checking tomorrowAre you sure you have the cable through the correct hole in the gear selector on the brake lever? It is possible to miss this when fitting but still get the cable into the outer cable and run it.
Got a piccie?Lever is missing some of the shiny plastic stuff that covers the silver bit where my fingers have rubbed it off. There's also a couple of scuffs.
If you want it PM me with what you think is a reasonable offer (I'm useless at putting a price on things!)
It is but I trust you so not blaming you Loco.Tony is this my one? It was deffo working when it came off, as mentioned above try holding the cable to ensure its moving with the lever movement?
Also pull the cable tight when it is on the 11t not mega tight but defintely not slack
I'll sort something out but it will be tomorrow evening now. The scuffs will probably show up but doubt the shiny bit will.Got a piccie?
