oldgreyandslow
- Farnborough
I have an 11-28 rear cassette at the moment and see you can get a 12-30 ultegra now, will this be ok with my 105 rear mech compact set up?
I fitted the cassette, got the chain length right but indexing is not at all good. If I adjust the tension at the low end as in the instructions, large chainring 2nd and 3rd rear cogs etc I get it to change fine but then when on the small chainring and larger rear cogs it won't shift cleanly from 4th largest upwards. If I adjust the tension to get these right it screws up the change on the smaller sprockets.
Is it just a case of the rear mech not being as accommodating as the newer ones or am I missing something?
Thanks, I had those instructions, I am pretty sure the b screw is fine but will pull the cable through the clamp a bit more to give some more adjustment range on the tensionerNot sure which 105 model you have, but have you ensured the B screw is squarely on the hanger tab, and the cable is clamped correctly? For RD5600 e.g. see this.
Lube and flex your cables. Then re adjust... Particularly the bend from Frame to derailer. Gets stiff bent and dirty..Thanks, I had those instructions, I am pretty sure the b screw is fine but will pull the cable through the clamp a bit more to give some more adjustment range on the tensioner
Cheers
