gb155
Fan Boy No More.
- Manchester-Ish
Much cheapness pls
Will collect
Will collect
Huge thanks, would it need a weld do you think?I have a 60 cm Ribble alu racing frame with a small crack (doesn't seem to have any effect on its performance) you can have if you want. You could get it welded for piece of mind for not a lot but the paint would need to be sorted out. It is going to go on free/exchange anyway when I have stripped the groupset.
Your fair amount of power and Gaz's might be vastly differentI haven't had any issues with it and the rode The Macc Monster end of last year on it so put a fair amount of power through it with no deteriation. For the cost of a weld though it might be worth it so you don't worry about it too much Pic here
Sounds perfect, thanks very much mateMost metal fabricators will weld alu, should be quite a few around Stockport. Cost shouldn't be much £20 maybe, you might need to do a bit of a ringing around. You would have to sort the paint though for a good finish/look. I would be tempted to rattle can it if you are going to use the frame as a beater.
Nah, I'm old n slow these daysYour fair amount of power and Gaz's might be vastly different![]()
It's gets even betterI'll need to take the groupo off it, which I will sort over the next couple of days. Might have a fork that will fit it if you want it.
