700 28-38 or 20-28
maddog.mark
Norfolk
So which is best if you have a 700 28 tyre? Having just blown up a 28-38 as I inflated it, must have pinched it and not noticed I'm inclined to go for a 20-28 but would appreciate any views on the pros and cons if there are any.
Thanks and seasons greetings
Mark:smile:
andrew_s
Gloucester
Are we talking inner tubes?
Compared to 20-28, 28-38 will be more puncture resistant, but heavier and more prone to getting trapped under the bead.
maddog.mark
maddog.mark
Norfolk
Sorry yes we are. I was putting some Armadillo tyres on which should be puncture resistant so I guess the 20-28 should be ok then.
thanks for your response
Banjo
Fuelled with Jelly Babies
South Wales
And take up less room in your bag.
GrasB
Nr Cambridge
the Spesh 700x28c All Condition Armadillos came supplied with 700x20-28 innertubes. :smile:
maddog.mark
maddog.mark
Norfolk
GrasB said:
the Spesh 700x28c All Condition Armadillos came supplied with 700x20-28 innertubes. :eek:
Mine didn't but my 20-28c arrived today and have been fitted to the bike without further explosions!
thanks for the comments all:smile:
andrew_s
Gloucester
Alien8 said:
Why's that then?
Unless an inner tube has Slime or suchlike in it I would image they have approximately zero puncture resistance regardless of size.
Smaller tubes are stretched more, and much easier to damage than a comparatively unstretched tube. Try cutting a rubber sheet or a bit of old tube with a knife.
examples...
You may have something inside the tyre, like a bit of grit, split rim tape or an exposed spoke hole.
A fragment of glass may have just the very tip getting through the tyre. A small tube will puncture straight away, but a big one may last long enough to show up as a slow puncture that you can fix at home.
A thorn may plug the hole it's just made. I've ridden for over a month with a slow puncture (pump up every other ride) that turned out to be a thorn that had gone a centimetre through the tyre
