Aero bars for longer distance.
Hello,
I see that a lot of Audax riders have aero bars fitted as it seems to relieve pressure from hands and back and gives a performance gain on long distance.
Do you change the whole bike set up or just adjust your body position?
Many thanks.
S-Express
That..
G3CWI
Macclesfield
I came to the conclusion that the gains were less important to me than feeling safe and comfortable on the bike. Quite fun to try though.
Mugshot
Cracking a solo.
I find them pretty good, although they can get a bit melty if it's too warm.
Mugshot
Cracking a solo.
I enjoyed using the more standard aero bars although I did find I had to mess about with them before I could fit them in a position where I could more comfortably use the top of the bars whilst climbing, and even then it wasn't great. The set I used I'd borrowed from someone that couldn't get on with them, I've seriously considered, but not quite got round to getting my own set but I would probably want the type with the flip up pads for the reasons stated above.
Edit: Forgot to mention I didn't change the bike when I was using them, just myself.
Cuchilo
Prize winning member X2
London
@frank9755 Has his set up pretty well .
screenman
That is one of the problems - it's a lot easier to nod off on a long ride if you go on the aerobars.
I would hope that you would get off befors things got that bad. Personally on my old time trial bike the position was very comfortable, that said I was never into long rides so about 100 would have been my max distance.
frank9755
Cyclist
West London
Hello,
Many thanks.
It's always a bit of a compromise as the two positions are different. Generally I'd say don't mess with your main position but work on flexibility so that you can use the aerobars without adjustment. However, this means your hip angle will be very tight when on the aerobars. I've got a seatpost that has two positions (Redshift), so I can get something more like a TT position on the aerobars without ruining my drop-bar position, but I don't always use it as it's not always comfortable. A lot of people, such as Steve Abraham, get round the tight hip angle by having their aerobars very high which sort of defeats the point, or minimises the benefit.
Best way to start is to put them on, without otherwise changing your position, and use them for short periods only to begin with, then gradually extending the time you spend on them.
frank9755
Cyclist
West London
I've never had a problem on hundreds, 12s or 24s but I became aware of it during the Transcontinental. When you are very tired, the prone position is just a bit more sleepy. Apparently Wilko cited it as a problem when he did his LEJoG record ride.
