I learnt a very important fixie lesson last week - the hard way.
You may have heard of a technique for cleaning your chain called the 'mickle method'. While this is a great method for quickly cleaning your chain don't ever - repeat - EVER use it on a fixie.
Our very own Mickle described the technique where (correct me if wrong) you essentially dowse the chain in lubricant and run it through a rag to clean the outer plates and remove debris from inside the chain. I do/did this by turning the bike upside down and turning the pedals by hand. I have never had any trouble with a freewheel bike but with a fixed the motion of the rear wheel will keep the drive train moving and the rear wheel can have significant inertia.
The upshot is if the rag gets caught in the sprocket it will be pulled in. The drive train will not stop as it would if the rear wheel had a freewheel, the momentum will keep it moving. This is a problem if you are holding the rag with your fingers.
My finger remained attached but the bone at the end was broken (first broken bone) and the tissue was almost cut through. I went to a plastic surgery clinic and they say it should be ok but it may not grow back completely straight and I will have a bump on the nail when it grows back.
BTW - Mickle if you are reading, don't worry. I blame nobody but myself for spinning the wheel too fast and not considering what might have happened.
