- South Manchester
Sounds like the hard drive
could well be... I've run the windows error checking to on the C drive, which seemed to find things and do things and re-jig things... just have to wait and see if it's made any significant difference.Sounds like the hard drive
Honestly, do some googling. There are already a number of exploits that can switch off your AV software without it or you being any the wiser. Continuing to run XP is madness.Surely any exploits have to get through first
Yes, I have just the one HD, which is backed up on to my other three HDsIf you only have one HD, I hope it's backed up.
The PC seems ok so far, since i did the error checking/fixing thing on my C drive... but.. oh no... that'll that there fate tempted
i used the windows tool on both particians in the first instance... then downloaded the tool from seagate, which painfully 'encountered a problem and needs to close', and therefore did nothingWhat I meant by checking the HDD is not for errors on only C. And if you used a windows feature you used the wrong tool. You need to see (in your hardware devices) what brand is your HDD and then get a tool from the manufacturer (there will be a free one on their website) to check the HDD. And I don't mean only drive C but the whole drive, since the memory reads everywhere (use such a tool overnight or when you are gone for a long time).
What you have as a part of winXP is a tool to fragment the hard drive. All this does is to switch around bits of information to make the reading easier and faster.
