swee'pea99
Can I put pretty much any counterweight on a tonearm (that's lost one) or does it have to be 'the right one' for that tonearm?
Thanks if you can help.
You may even find that the correct counterweight is available as a 'spare part' as some manufacturers make a couple of different weights to suit either unusually heavy or light cartridges.I suspect they are not a standard size (although certain manufacturers may have a specific size/weight). Do you know the make and model of the tonearm? If you post a photo someone might be able to identify it. If not, there are knowledgeable people at https://www.vinylengine.com
That's a Rega arm (looks like the RB250) , loads of standard and 'uprated' counterweights available for them.I don't know what it is (and neither does the current owner) but it looks like this:
It's certainly one of the ones that are listed for that counterweight (Rega arm with plastic stub)Something along these lines perhaps ?
http://www.ebay.co.uk/itm/Rega-Coun...251-Tonearm-Weight-Genuine-DECO-/322505856124
Assuming that it is an RB250...
