Roger Longbottom
W
Try unscrewing that, slide it out, and you should / might be able to lift the whole panel off the runner. Careful, though, they can be heavier than they look.There is this little chap which appears to be held in with a small Allen bolt.
Ah I see, Like @Kempstonian I thought they were full height.They both slide, the inner and the outer.
I they are that and they will require a wheels or some form of ball bearing. If it’s a ball bearing then they were built not to be removed for security reasons.They are windows John, not doors, they just slide on runners. Here is a full product picture I took earlier.
