ChrisEyles
- Devon
I've been looking at replacing the old elastomer fork on my late 90s Marin for a rigid steel fork.... and quite frankly I am getting very confused about axle to crown distances!
The current fork is around 450mm at full extension, or 443mm with sag (when I'm sat on the bike).
It's only a 50mm travel fork, and the online recommendations for <80mm travel forks all seem to suggest a rigid fork of around 410mm axle to crown. This would obviously lower the front end of my bike considerably, and to be honest the front end already feels low enough to me, with the steering nice and sharp.
I was looking at a set of surly 1x1 forks with 453mm axle to crown, but this has a suggested suspension correction of >100mm - much more than I've got.
So I'm confused! Should a rigid fork be matched to the height of the suspension fork (minus sag), or should you assume that the fork is going to be partially compressed a lot of the time you're riding and go a bit shorter?
I've seen a nice pair of period forks with an axle to crown of 425mm at a good price - is this likely to be a happy medium or am I likely to find the steering overly twitchy (and live in fear of flying over the bars on a steep downhill!).
Thanks for the help!
