scotsbikester
Pre cycling holiday checks.
Front wheel out. Measure thickness of pads. Avid say friction material+backing should be => 3mm.
Failing eyesight means Vernier guage not quite accurate enough. Out with the micrometer I recently inherited. Work out how to use it. Then measure, in several places. Which was remarkably consistent.
That's an imperial micrometer, but if I've a) read it right and b) converted to metric correctly, there is 3.683mm of pad+backing on that used one.
So how much is there on a new one? I hear you ask:
That's 3.987mm. No, no, no, that's not "nearly 4mm", this is a very carefully controlled precision study.
Avid say 3mm is wear limit. So 3.987-3.000 is 0.987 wearable material.
My worn ones have used 0.254 mm (3.987-3.683), 25.7345% of the wearable material.
I log every ride using either my phone or sports watch, and track component usage using Quantify my bike. Those pads have done 2020 miles.
So Avid BB7 pads (these are the Avid metal sintered ones) last for 7,849.38506674 miles.
Approximately.
Approximately.
