This is a bit of a read with no real purpose other than as a ‘newbie’ to this forum and as someone trying to get a bit more time in the saddle I wanted to share a few things that may be useful to others in a similar position:
I bought a Boardman ADV 8.6 [gravel or adventure] bike. I debated between this and a hybrid bike but went with this option as I was persuaded by a friend that a drop bar [rather than straight handlebars] gave the option of dropping down to a racing position which is handy when pedaling into a wind and the flexibility of having a few different riding positions.
The same friend recommended carbon forks although the case for that was less clear but I went with it and as I don’t have a frame of reference for comparison I can’t comment on the value of doing so. Apparently as well as making the bike a bit lighter carbon forks absorb some of the bumps better.
I am 5’ 9” and went with a medium frame size. The saddle only needed to be raised slightly – just enough to mount a rear light on the seat post. I think I probably could have went with a frame size up but due to shortage of bikes physically in stock I wasn’t able to try them out. Medium seems fine though.
The chainset [if that is the correct phrase – front cogs] are smaller than most standard road bikes but maybe not as small as mountain bikes which means you might run out of gears when going fast eg down hills but that has not been a problem for me so far and I have been glad of the ‘easier’ gears for going up hills which might have been a challenge with a standard chainset
The tyres are wider than a normal road bike and probably similar to a hybrid [38mm] – I think this makes for a more comfortable ride and even if the bike is not taken off road very much they are good for our pot hole infested roads.
I ordered my bike online from Halfords who seemed to have a decent range of bikes available and I opted for the [free] in-store delivery and build service. This was probably the most negative part of the story so far, the build was not good. Gears did not work [chain would not move from small front ring to larger front ring and vice versa] also the brakes [mechanical disc] were not sharp especially the front brake – I did try the recommendations on-line re bedding in. So I had the bike back a few times and got at least a partial resolution – they ended up having to replace one of the gear cables. I did buy the maintenance plan as well and I will take in on for its free service at the appropriate time. I still have another gear related problem – when the chain is on the bigger of the front rings / cogs and I apply load [pedal hard / going up hill] the chain jumps from cog to cog of its own free will. I think this is just an adjustment and might try to read up on it here or else bring it back in to the store.
I also recently bought a set of shimano EH-500 pedals which are standard ‘flat’ pedals on one side and SPD pedals that you can clip the appropriate shoes / cleats into on the other. I have used the flat side of the pedals and they are good but I am still waiting on my shoes coming to try the SPD side.
All in all I am really enjoying getting out on the bike more and really glad I stumbled onto this forum – I have already really benefited from some of the great advice and general banter
