Bike lights. Different modes?? when to use which mode?
Randombiker9
So bassically I got some bike lights as after half term it will be getting dark earlier. But they have different modes. So how do you know which is the best mode at the time?
Front:
1. Steady bright
2. Steady (even brighter)
3. Flashing
Rear:
1. Steady
2. Flashing
3. Flashing ( even brighter.)
presta
In a streetlit area I use flashing on the front to be seen, but continuous outside the streetlit zone in order to see. I feel on the verge of an epileptic fit if I use flashing in the pitch dark. On the rear I use flashing all the time, because I did a test and found that overtaking drivers leave more room when it's flashing.
Mugshot
Cracking a solo.
Never, ever flashing on the front. Flashing front lights says "Cyclist", people like to pull out in front of cyclists because they only do 8mph and will hold motorists up. Flashing front lights also make it more difficult for other road users to judge your speed and distance.
mjr
As do flashing tail lights.
I use steady lights front and back with reasonably large illuminated surface areas, hopefully to leave the motorist thinking I'm a larger vehicle (so more likely to dent their precious if they hit me) until they're close enough to see the pedal reflectors bobbing.
Randombiker9
Randombiker9
interesting.
My own policy, which is likely to be no better nor worse than other people's is: Front steady. Front steady brighter if no street lights and/or if no chance of running out of battery during the ride. (Front flashing only if the battery is about to expire and I have to be very frugal with electric. I find it annoying) Angled down to light road ahead. Rear, flashing unless in a group ride, in which case steady. Normally I have two at the rear, one flashing, one not.
Ok thanks
Steady at all times on both lights. Strobing and flashing everywhere just pisses everyone else off.
Probs just your area I guess. (What area do you live in out of interest?)
Interesting. What do you think about rear lights then?
ok interesting
My college commute is bassically straight, roundabout, straight, shortcut (shared path), cycle path, roundabout, bus lane. On the way back it's bus lane, roundabout straight, bus lane, shortcut (shared path) , roundabout and then straight.
Mugshot
Cracking a solo.
:laugh: I mean that flashing is subconsciously associated with "slow vehicle - nearly static" so they more often pull back in before they've actually completed the overtake, especially if I've got a rare tail wind...
That's not something I could say I have ever noticed. I'm not a huge fan of flashing lghts, some of them are damn annoying. However, I do think that they're more noticable from a distance. My rear lights have a rather natty throb mode that I'm quite partial to.
Mugshot
Cracking a solo.
I don't mind flashers on the back, as I said above I do think they are more noticable. Some of them with the daft random strobe effect are very annoying and stupid too, you don't want people to be desperate to get past you because your lights are so annoying, likewise the type that flash normally then emit a searing flash every so often, it's enough to give you arc eye if you're behind them for long enough.
Vantage
Carbon fibre... LMAO!!!
Few people will argue that a flashy stroby light will attract more attention, however due to their on/off nature, it is harder to gauge their distance from the drivers point of view which could result in moving out to pass too late. The driver about to pull out from a side street further up the road from you would also have more difficulty in judging how far away you are.
Clanghead
Southampton
I find that (other riders') flashing lights show up better in a street-lit urban environment, but I take the point about judging speed and distance. I usually use a slow pulse on both front and rear (partly to conserve power) during my urban commute, but the other evening I switched my front light to steady brightest before approaching a particularly narrow stretch between rows of parked cars, and compared to my usual experience there, it did seem to slow down oncoming cars who perhaps weren't quite sure what they were about to drive into.
