Boardman ADV 8.9 vs CX 8.9
Phil4000
Recently got a Boardman slr 8.9 used, at an excellent price and excellent condition. Absolutely loving it.
However, I would like to also have an off road bike more for light off road and trails than mountain biking as such. Thinking of staying within the same price range for now, if I get really into it I'll start splashing out on more expensive bikes.
Am very happy with the build quality and performance of the Boardman. So am considering the CX 8.9 or ADV 8.9.
Like the rugged look of the CX, but does seem a bit heavy at 11kg. The ADV 8.9 is 10.5kg. Wondering if either of these bikes would do for now, or if I'll be restraining my enjoyment due to the weight?
Thoughts appreciated...
It's 500g. A new saddle will halve that.
10kg is fine. It's not exactly heavy. My Colnago CX is about 10kg - it's alloy/carbon. My old vintage road bikes are 9kg, but they were well specced ones for steel.
N0bodyOfTheGoat
Hampshire, UK
I'd be more concerned about getting something following the trend of more tyre clearance, for example the Ridley Kanzo can do ~52mm clearance in 1x or ~47mm clearance in 2x. Are the Boardmans still limited to ~45mm?
https://www.paulscycles.co.uk/bikes...lu-grx-2x-gravel-adventure-bike-bronze__14841
The carbon Boardman adventure bikes from around 2020 had a good rep and will save you a bit of weight over alloy, but it's more $$$$ and you might not notice the weight savings if you aren't a skinny racing snake.
Seevio
South Glos
Newer carbon model?
No. 2021-ish Al frame with C forks.
The biggest difference between the bikes will be tyres. Off road tyres will be slower, but depending on tread design/construction, they may not be much slower. I have some light gravel tyres - light tread on the rolling surface with side knobbles. They do rather well as an all round tyre, and considering they were just what I could get on the day in Decathlon (B-Twin Gravel Light) they have done the job for 3 years, including some challenging bike packing. They roll well enough that I am happy to use on tarmac when I'm mixing a route up. I do have spare wheels with good road tyres on that do make a difference to speed, but it's not like switching from fast tyres to say MTB tyres, or the chunky things on my commuter.
P
Phil4000
From what I'm reading, the geometry is less aggressive on the gravel bike. Which would be better for all day out and about. May look out for a ADV 8.9 or 9.0.
