Hi,
I recently got a 2013 Boardman CX Team from Halfords. I haven't ridden it yet, as I need to fit the pedals.mudguards, lights etc. However, I noticed there was a small paint chip on the top edge of the head tube, so I took the handlebars off the sterrer to get a better look under the headset cover. At this point I found that the carbon steerer has both vertical and circumferential notches in it that can be felt with your finger (not just fingernail). The vertical one is about 1mm deep, while the horizontal one is about 0.5mm deep. The vertical one has loose material in it which comes out when you scrape it with your fingernail.
I took it to my local Halfords (not the one I got it from), who took a (very) cursory glance at it and said "it's only surface scratches, there's still plenty of carbon left, and anyway we can't get replacement forks for that model so just ride it". I asked about a refund and he said "well you'll have to take it back to the shop you got it from so they can explain why they signed it off as roadworthy". Also, he told me that the bikes are exempt from their 28 days returns policy(!).
I had another look at it last night, and to be honest I'm not happy about it. I have another carbon bike with full carbon forks, and that doesn't have a mark on the steerer, despite the fact that I've adjusted the handlebar height several times. When I picked it up, I noticed they had the handlebars at right angles - they duly loosened the stem slightly and then twisted it round before tightening it up again by hand (no torque wrench in sight). Clearly, there is a sharp edge on the stem which when they twist it round is scratching the carbon steerer.
When I check the installation instructions of carbon forks online, they all say to be careful not to scratch the steerer with the stem (as Halfords have done) as even small scratches may weaken it and cause injury or even death(!) to the rider if it fails.
Clearly I have the choice of trying to return it to the store I got it from, or just riding it - I've got a couple of young mouths to feed, so I can't take the risk unless I'm 100% sure it's safe. What do you guys think? Here are a pic...
