PapaZita
- St. Albans
Hello,
I've got an old steel frame that I'd like to convert to fixed. My concern is that the bottom bracket is a bit on the low side. I measure it as 26cm/10.25" (floor to centre). I'd be using it with 165mm cranks and Time RXS pedals. A quick experiment suggests that it'll lean over to about 36 degrees from vertical before the pedal touches the ground. What do you think? Will it be OK or should I look for a different frame?
PZ.
PZ.
