Kiwiavenger
im a little tea pot
- Carclaze, St Austell
i had a fettle last night and changed the brake pads on the allez, it had standard shimano pads before on tektro calipers. all fitted in fine and all lined up smartly. the problem i have is the front brake has a lot of pull in the lever, i tried using an extra washer on the pads (new clarks shiny silver ones!) but that just then jams the wheel! i've fiddled with the cable adjuster so it slows me a bit, but still has loads of travel and i engage them fully, i still have really weak index and middle fingers on that hand after an accident but they are fine with maybee 1-2 cm's of pull but really struggle after that so the less reach on the levers the better!
would it be worth me getting some thinner washers and trying them? or moving the washers to the inside (between pad and caliper rather than between caliper and nut?)
