Braking issues
Ollie W
Cycling pls
Southampton
My Boardman CX Comp brakes have suddenly stopped being particularly effective. I've lost the bite in them that I used to get when I engaged the lever and they especially don't seem to like coming to a stop - at the last few miles an hour the front brake especially starts screeching. The only things I did before this happened were lubing the chain and removing/replacing the front wheel because I'm getting a load of vibration in the front wheel too whenever I'm on any road that's slightly less than perfectly smooth. Has anyone got any ideas as to how I can fix this? I don't think the brakes have failed, they're only six months old, but I think I've done something stupid haven't I :sad:
ianrauk
Tattooed Beat Messiah
Rides Ti2
Tektro disc brakes right.
As you brake the pads wear, so you need to adjust and tighten them.
Globalti
If the brake makes a horrible squawk and judders as the bike rolls to a stop, the pads and disc are contaminated with oil. Put the pads in the dishwasher and clean the disc with alcohol, or glass cleaner or hot water with detergent.
:eek: my dishwasher is human. he may object and I am not that certain they will come out any cleaner!
screeching and vibration on mine disc pads turned out to be a number of issues... firstly one of the callipers was not working properly - that needed a touch of tlc and some tactful persuasion but it was returned to life... secondly they needed to be recentered... loosen off the 2 nuts holding the calliper unit onto the forks, apply the brakes several times then hold the brake on, and re-tightened the calliper nuts... I needed a couple of attempts at this sadly... but don't do any of this until you have checked that your pads are OK and not worn down - useful check because you can see if they are wearing unevenly....
