I need to buy a more corrosion-resistant chain for the Brompton and wanted to check with the more learned that I'm getting the correct type.
I've been perusing this excellent resource and think I have it nailed, but wanted to be sure.
I frequently read that the Brompton chain is 3/32", apparently referring to the roller width that's universal on all 5-8sp chains. I've measured the width of the existing chain across the pins at 7.1mm; which suggests an 8sp chain. The SRAM quicklink on the current chain however states "7 speed".
It seems that 8sp chains are slightly narrower at 7.1mm than 7sp chains at 7.3mm, but the 8sp is backward compatable down to five speed.. and in any case mine measures as an 8sp even if the QL states 7sp (which I suspect may well be interchangeable too).
So.. can someone please confirm that the bike requires an 8sp chain..?
Ta
Ta
