Budget 6 speed shifter and derailleur
Okeydokey
I'm looking to add a derailleur and shifter where the last one had been removed on a Raleigh Vixen. Previously it was a twist grip but for the purposes of this exercise I would like to add a trigger mechanism.
If I go down the SRAM route, I can find the X3 range which provides for a 7 speed mechanism. Any other reasonably priced options spring to mind? And where can I find a reliable supplier...
Edit: Meant to ask, can I use a 7 speed derailleur and shifter on a 6 speed bike?
Arjimlad
Tights of Cydonia
South Glos
Just a thought - 6 speed bikes are usually freewheels rather than cassettes.. would this be a good time to put a 7 speed freewheel on ? Might widen your choice of shifters..
tyred
Ireland
I would use this shifter - http://www.ebay.co.uk/itm/6-SPEED-R...561?pt=LH_DefaultDomain_3&hash=item2a506adae1 for a 6 speed system and it should work with a 7 speed derailleur.
Have a look in the local dump/skips/river you may even find what you need for free.
If you want to go 7 speed options, then I think there is a 7 speed version of that shifter too if you look. Changing to cassette hub should be easy on a mountain bike but may cost more than you are willing to spend on it.
