Burning Google Play MP3 to CD?
Panter
Just call me Chris...
So I've just bought an album from Google play and downloaded it, it's in MP3 format.
If I copy that to CD, I guess my 10 Year old CD player won't recognise the format so I need to convert it, is it a .wav file?
Is there a techno numpty friendly way of doing that?
Diggs
You should be able to burn a cd with Windows media player (or other audio software if you have it - I think apple iPlayer has burning software if you already have for example). Assuming you're running windows have a look at this http://windows.microsoft.com/en-gb/windows-vista/burn-a-cd-or-dvd-in-windows-media-player . Just select Audio CD as output.
Panter
Panter
Fantatstic, thanks for that, I tried it, and it burned as an audi CD but the player won't recognise it.
I'll have to look into it further, it might be the disk type or something
shouldbeinbed
Rollin' along
Manchester way
Use something like itunes or windows media player etc to create you a music CD that a non computer optical device (CD player) will recognise, rather than making a disc of computer audio files.
Panter
Panter
I did that with Windows media player as above, I do wonder if it might be the type of disk it is though. It's a RW disk which I seem to think some older players aren't compatible with? will have to get Googling
Just a guess but with some older CD players you may need to finalise the CD
shouldbeinbed
Rollin' along
Manchester way
Ah yes, sorry I skimmed past that post. RW stands for rewritable, basically you can subsequently add to it rather than the R type which is a one burn pony whether you fill it or not. I'm not an expert but I wouldn't have though that would make much of a difference, unless the CD player looks for the finish bar that the R type closes its burn session with to know where to stop reading the disc.
Panter
Panter
Finally got there. Two failed attempts first as the default setting is for a data CD which needs to be changed to audio CD, I hadn't spotted that.
Thanks for all the help, it was greatly appreciated :smile:
