Cannondale Bad Boy 2 Cages...
Boon 51
Deal. Kent.
I'm having a bit of a problem in getting the right bottle cages for my Bad Boy 2
All the ones I've tried have fitted OK until you put the bottles in, then the bottles touch and are not seated properly.
I have measured my other two bikes a Trek and a Specialized and the bottom hole is 8 inches up from the bottom and the Cannondale is only 7 inches from the bottom, hence no room..
Hope that makes sense.
So what should I look at for the cages..
I have no knowledge of the bike, but the position of the bolts on bottle cages is different between models and makes.
Is it possible that a Cannondale cage has this hole lower and closer to the bottom of the cage, physically putting the cage higher?
Boon 51
Boon 51
Deal. Kent.
All the cages have tried I have lifted the cage as high as it will go on the adjustment, but they are still too near the bottom and the bottles clash?
But I will google and see if Cannondale do cages.. :smile:
Boon 51
Boon 51
Deal. Kent.
Your right the plastic one looks better.. hopefully hear about the Blackburn's tomorrow.
I just need to know I can fit two cages.. pesky things.
Boon 51
Boon 51
Deal. Kent.
Why not give pedalon a call, they probably sell the bike you have
If I dont get much joy from my email I will give Pedalon a ring..
PS.. As its a problem I might be able to get carbon one's and not get into trouble with SHMBO :biggrin:
