Zippy
- Camborne, Cornwall
I am fitting new cantis (TekTro, linear spring) and they fit fine with new cables, sleeves etc, but the drive side needs to be about 5mm away from the rim before the non-drive side relaxes away fromt he rim to allow the wheel to spin. Obviously now the brake lever is too slack.
Not much of a wobble in the wheel rim.
Seems the whole wheel is too far over to the drive side, but I can't see that I can shift the wheel over without misaligning the cassette to the rest of the chainset.
The brake set is not the type where you can back off the brake block housing. If I pull the block that is too close away from the rim it settles back to the rim.
I have the springs slotted into the middle hole in the braze on; maybe I should go for more tension - although the other three brake arms front and back are fine.
Is it the wheel?
Is it the wheel?
