Cantilever brakes on a fixie...
I've recently bought a second hand Carrera Subway fixed gear (well, flip flop hub) bike as a bit of a project, and am looking at giving it drop handlebars as it currently has incredibly wide flat bars. Reading across the internet it would seem that the perception is V type brakes don't work on a road bike. But why is this? Will they work on my fixie? It's fairly obvious that I'll need to change the brake levers as the current ones won't fit onto a drop handlebar, but will the new levers (I'm looking at Cane Creek levers from Chain Reaction) work with the current V brake setup, or will I need to change the brakes to cantilever type?
TheDoctor
The TerrorVortex
Drop levers that work with V brakes are like hen's teeth. Dia Compe make (made?) one - the 287V or something equally snappy. Any road lever will work with mini Vs or Cantis.
B
BenBlundell
Regular
Ahhh, got you! So a drop brake lever doesn't pull as much cable as a flat brake lever, so I'd need to change the brake mechanism as well as the levers.
mcshroom
Bionic Subsonic
But if you want to do so, then there are v-brake specific levers.
I have Dia Compe 287v levers on my hack singlespeed, and others include levers like the Tektro RL520. Another option is to use 'mini' v brakes such as Tektro RX-5 which use normal drop bar levers.
Cantilever brakes are more effective than a lot give them credit for though. Especially if you get the longer armed versions.
B
BenBlundell
Regular
So it's not as simple as getting the cable as tight as possible then. When I get round to doing to conversion, I'll go for the Dia Compe levers just to be on the safe side. They aren't a lot more expensive than the ones I was looking at anyway.
TheDoctor
The TerrorVortex
Can't help feeling that V brakes on a fixed might be a tadge overkill. A bike as light as that won't take a whole lot of stopping.
Dead easy to skid though!!:becool:
