Carrera subway 2 vs Boardman HYB 8.6
Hi guys,
Looking to get a new bike to use as a form of exercise. It’s mainly just for leisure which I’ll be using a couple times a week max.
A close relative of mine sells bikes and has offered me mates rates for the following two bikes (new)
Carrera subway 2 - £250
Boardman HYB 8.6 - £370
Which one would you recommend? The bike won’t be used extensively hence do you think it’s better to settle for the Carrera? Will I notice a big difference in the ride between both of them?
thanks in advance
sleuthey
Your supplier will save you 130 on the 8.6 and 100 on the Subway 2 so I would take advantage and buy the 8.6
gzoom
The Boardman 8.6 has the same frame as my 8.9e - which cost £1800. I'm not sure if that is a good thing or not :smile:
Mfezela
The Carrera is 27.5" wheels, the Boardman 700c.
Carrera will accommodate up to 2.25" (56mm) wide tyres, the Boardman only 28mm.
Carrera is 3x9 (27 gears) drivetrain, Boardman is 2x9. You'll notice the difference in very hilly terrain.
The Boardman is lighter* and has better quality components. Both bikes can be easily upgraded should you so choose. *For recreational/social riding, lighter isn't always better - the ride can feel harsher especially on the narrower tyres.
Carrera has rack and mudguard bosses, Boardman doesn't.
The Boardman will probably hold its value better for resale.
The Carrera is tough as old boots.
I have a Carrera.
