Cassette Wobbling
Hello, I've not come accross this before and was wondering what the explanation is. When I took my rear wheel off to clean out the build up of crud that was between the sprockets I noticed that the whole cassette has a slight wobble in it when you, well, try to wobble it. Is the cassette lock ring loose? Is my freewheel worn? Is it something else? Is it normal? I've never noticed it on any of my previous bikes. It's a Shimano XT hub and cassette. Thanks in advance.
Try and tighten the lock ring first. That is the most likely cause. It does not need to be very tight so don't force it. Just nip it up, slightly more than hand tight.
