chain wear/new chain...
Maz
I just checked my chain. I put it into highest gear (largest front chainring/smallest rear sprocket)...is that the combination when the chain is at its tightest? Anyway, I am still able to comfortably pull (laterally, from the right-hand side) the chain away from the largest chainring with my fingers. Is this a sign of wear?
i Also did the 12-inch/12-link thing and there is a big mismatch (more than 1/8 inch). A lot of gunk on chain, esp around the jockey wheel.
Can anyone recommend a 9-spd chain replacement? do most come with a powerlink? This is for my allez road bike. thanks.
also How do you clean a chain?
thanks
I buy this one come with a power link
As for cleaning I wash it off in white sprite leave to dry, refit and spray with WD40, yes I know some people don’t like using WD, but I get 6500 miles out of my chains, but I spray it on every other trip after I come home
potsy
Rambler
My Armchair
thanks
Is Maz on a wind up here?:biggrin:
Maz said:
Thanks, numbnuts. Does that chain come with a powerlink to fix the 2 ends together? Couldn't see anything in the product description that confirms this.
yes
The PC-951 is our most economical PowerChain while still maintaining our high standards of quality. Like all Power Chain II chains, the PC-951 uses Chrome Hardened rivet pins for increased durability. The PC-951 uses grey coloured plates, as well as our PowerLink closing system.
Tynan
e4
mine now has two powerlinks after a break on Friday, fortunately 100 yards from the house at the bottom of the initial hill as sir put his first heavy foot down
it runs a hell of a lot smoother now, so I suspect a dodgy link was there for some time
there's a third link in the pannier now just in case so I may make three
