Finn
Slowly getting an SS build together on an old Falcon racer. Horizontal dropouts on rear & 113 BB square taper. Dished rear wheel with shimano 18T freewheel.
Tested out chainline with an old 36T mountain bike crankset (pressed type) and its a perfect line.
What i need help on is knowing what budget 42-46T cranksets out there are likely to be a good line. Are there measurements I should be checking out first?
From what i can tell from pictures online, single cranksets are flat on the inside which i think is needed for the best chainline.
Insight gratefully received
Cheers
Cheers
