Chainring - life left in it?
I am Spartacus
N Staffs
I think it has plenty of life left in it.... ? but no expert
This is the old cr and the bike has done at least 2.5k miles
Have just bought compact 34 and want to swap it back to the 39 for most rides..
rides.... ?? most time now spent fettling the bike...:smile:
gbb
Peterborough
I dunno...it depends on a few factors.
What speed ?, 8, 9, 10 ?
I replaced the chain on my 10 speed a few months ago...chainrings looked ok, cassette was showing a bit of wear, but i thought it'd be ok....and it's worn the new chain excessively fast.
8 speed (which i know it's unlikely to be) is pretty indestrucable, 9 speed wears that bit faster, and boy...do you have to take care with 10 speed.
I'd say for 10 speed, consider your options very very carefully.
gbb
Peterborough
If you're still going to run the same chain, i'd probably fit it.
If you look at about 8 oclock particually, you can see some wear, the bottom of the teeth appear more dished.
02GF74
yeah, that'll be good for a few thousand miles yet. I;ve had rings whcih still worked perfectly when the odd tooth more or less was not there :smile:
RedBike
Beside the road
When a chainring wears the teeth start to look pointed and 'sharp'. Those teeth still look nice and flat at the tip so I would say there's loads of life left in it.
Thankfully chainrings on road bikes last a lot longer than 2500miles.
alecstilleyedye
nothing in moderation
i'm with redbike…
I am Spartacus
I am Spartacus
N Staffs
btw.. to clarify it's FSA kit
:tongue:
there are a few bike snobs on here that would look down on such lowly kit .. if they read this , they know who they are
I am Spartacus
I am Spartacus
N Staffs
'cept I can't re use it.. doh its 130bcd when new crank takes 110...
oh well, I used the compact yesterday and quite liked the gearing
