bonj said:Engine oil would probably provide lubrication, but you wouldn't put that on your arse.
bonj said:I'm not sure how you've determined that it's the same substance. Engine oil would probably provide lubrication, but you wouldn't put that on your arse.
simongrant said:Where did OP mention it being the same substance?
Simon
...or mustardbonj said:He didn't. But if it doesn't have to be the same substance, you might as well just use mayonnaise.
Joni said:I've found a cheaper alternative to Assos etc.
Neutrogena comfort balm comes in a similar tub, is a similar consistency, provides lubrication all day without being greasy and is about half the price. Just thought I would share that with you all.
Joni![]()
