Changing Brompton chain and sprocket
Yellow Fang
Bury St Edmunds
I'm thinking of replacing the chain on my Brompton and probably the jockey wheels. Maybe I should change the sprocket too. I see there's two widths of chain, 3/32" and 1/8" and several lengths. This is a bit of a pain. Does it matter which width? I have a three speed hub, but no derailleur, i.e. it's only a 3 speed bike. How easy is it to change the sprocket? Do you need any special tools?
RecordAceFromNew
Swinging Member
West London
Chain selection is covered here while sprocket parts selection is here.
3 speed hubs on a Brompton could be by Sturmey Archer or Sram, the former is more common. It is likely that the sprocket is held in place (as shown here) by a circlip. You might be able to find a pair of normal thin nose pliers to release/install it, but circlip pliers with multiple tips catering for different circlips are readily available for only £3 on ebay.
Sheldon has more than extensive info on SA hubs.
