Changing front gear cable
jamin100
Birmingham
My front gear cable is frayed and will need replacing on my giant defy. The shifters are 105 and the cable housing goes underneath the bar tape
Will I be able to feed the cable round rather than having to re-wrap the tape (it's not long been done)
Thanks
ianrauk
Tattooed Beat Messiah
Rides Ti2
Yes. Just done it recently.
ianrauk
Rides Ti2
Cable is a cable. Make sure you get a gear cable and not a brake cable as they have different ends. Also do not cut the cable until after you have threaded it.
slowmotion
Quite dreadful
lost somewhere
It's quite easy to do but make sure that you don't kink the cable as you take up the slack at the point where the new inner goes into the end of the old outer. It also helps enormously if the new inner has a cleanly cut end on it.
Edit: It also helps if you lightly lube the inner before trying to thread it.
