ChrisEyles
- Devon
I've just got hold of some new wheels with a rear freewheel 130mm OLN spacing and am intending to install in a 120mm OLN spaced frame. Thought this would be simple, but now I'm not so sure...
Am I right in thinking I may be able to simply swap the 130mm OLN axle on the new wheel for the 120mm axle from the old wheel? Anyone know if the internal "axle hole" of a hub has changed much in the past 50 years?
Otherwise if I replaced the spacer between the cone and the locknut with one 10mm smaller (bringing 130mm down to 120mm), and then carefully took 10mm off of the new axle (on the drive side) with a hacksaw (so that the QR skewer can still do its thing), would this suffice?
I'm guessing that if I managed to successfully change the axle size (or use the old axle) there'd be no need to re-dish the wheel, is that correct?
ps - I'm sure it will be suggested, but I'm not at all crazy about cold-setting the frame by that much - not least because I'd still like to be able to re-build and use the old 120mm wheel/hub at a later date.
