I have just tried for the first time a cheap 720p HD camera. A Poseidon 720p HD waterproof camera from China via EBay, for just £66 which includes delivery, it arrived very quickly.
The video quality looks very good for the price, in fact for just £66 it is excellent.
The only draw back is when compared to my ContourHD it is bigger and a little heavier, probably due to the waterproof housing.
It comes with a helmet mount, handlebar mount, car mount and a standard camera mount.
It records in 720p format 1280x720 at 30 fps, it encodes in MPEG-4 format, saving as .AVI type file.
It saves the file every 5 minutes and uses approximately 0.5Gig per 10 minutes, recording rate is 6.63M per second.
It uses SD cards not micro-SD cards, timestamp can be turned on or off.
From the description.
1、Primary Function: Waterproof Sports Action Video Camera
2、Lens: 120 Degree Wide Angle Lens (F 2.0, f=3.4mm)
3、Video Capture Resolution: 1280x720 (30FPS); 640x480 (50FPS)
4、Recording Format: AVI
5、Timestamp: On/Off
6、Microphone: Yes
7、Viewing Angle: 120 degrees (Wide angle)
8、Sensor: 5MP CMOS
9、Internal Memory: Built-in 46MB
10、External Memory: SD card (32 GB Max.)
11、Power: 1700mAH high-capacity rechargable battery
12、Water-Proof: YES, up to 10M underwater (IP68)
13 Buttons: Power ON/OFF; Record; Menu;Laser Light ON/OFF
14、Laser Light Distance: 20 meters
15、Laser Light Color: Red
16、Remote Control: Yes (10m operating distance)
17、Interface: Mini USB port (USB 2.0)
18、Output: 3.5mm A/V OUT & HDMI OUTPUT
19、Dimensions (mm): 80 (L) 40 (W) 50 (D)
20、Certifications: CE, RoHS, FCC
I will sort out a video showing it's picture quality later.
5、Timestamp: On/Off
6、Microphone: Yes
8、Sensor: 5MP CMOS
